Deletes a dynamic entry from the neighbor cache.
| vr_name | Specifies a VR or VRF. |
| ipv6address | Specifies an IPv6 address. |
| vlan_name | Specifies an IPv6 configured VLAN. |
| refresh | Refreshes the IPv6 neighbor discovery cache and deletes the inactive entries. |
N/A.
This command clears dynamic entries from the neighbor cache. The vr option is used to specify the VR or VRF on which the operation is performed. When this option is omitted, it applies to current VR context.
When the ipv6address or vlan options are specified, only the entries with matching IPv6 addresses or that correspond to that VLAN are cleared.
Based on the attributes you specify, the refresh attribute refreshes and deletes the corresponding IPv6 neighbor discovery entries as follows:
The following example clears all entries from the neighbor cache:
clear neighbor-discovery cache
The following example refreshes all entries in the neighbor discovery cache and delete inactive entries if the neighbor solicitation fails:
clear neighbor-discovery cache refresh
The refresh option was added in ExtremeXOS 15.7.1.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
